ANLAF
XS650 Guru
Fellers
Weeks of running absolutely smoothly, then a 75 mile ride. Accelerating 35-45 a sudden blank spot as if someone had switched the power off for a second. Bike continued back to smooth. It happened on the ride three or four times in the first say 20 minutes of the ride.
What could it be?
The first thing I like to do is ask: 'What have you done/adjusted/messed with before the blank spot appeared. the answer is I checked the plug gaps, cleaned and narrowed slightly on both plugs to more 6mm. Haynes says between 6-7mm, so I can't see the problem. By the way, the plugs are a pleasing lightish brown.
As far the carbs I recently stepped up the jets by one step each. Ran smoothly for 200 miles after that.
Any suggestions, fellers?
ANLAF
What could it be?
ANLAF
