jakobgoodnessgracious
Hello everyone, I found some help at this link:
http://forums.sohc4.net/index.php?topic=116447.0 . However, I am still a little confused.
I finally stopped a leak I was having from one of my petcocks and after a test ride and my joy of a successful run I forgot to turn them off. After I went back outside I noticed fuel dripping from the same black tube in the picture in the link. I know of the two carb overflow tubes and I am pretty certain from where the splash on the ground was that it was the black tube between the two carb overflow valve tubes. I tried to trace its origin with my hand but got stopped at the engine where it goes under a piece of metal or something. What I don't understand is that it was mentioned in the link up top that if one forgets to turn off his/her petcocks fuel could come from this blow by valve? How is this the case unless one has a faulty float needle or carb to even be letting fuel get into the crankcase (I think I'm understanding this right)? Shouldn't the overflow be taken care of by the carb overflow tube letting the excess gas out? Or is this just normal to have fuel come out of your blow by tube if you forget to turn off your petcocks?
Just making sure I don't have to fix something else. . .
