Hey guys, outta the blue my 79 special is blowing headlamp fuses. I might add that several years ago I fitted an early model right switchblock so I could turn the headlamp off at will.
When I put in a new 10amp fuse and turn the headlamp on (engine off) everything is normal. If I start the engine then turn the light on, the engine weakens and the headlamp fuse blows.
Surely I have a short somewhere, I've given all the obvious wires a once over but am not clever enough to know where to test with my multimeter.
On the topic of the wiring mods, back in 2008 I put a new mikesxs harness on the bike so solve all my existing gremlins. I deleted the RLU, Light Checker, and Self Cancelling Unit from the bike. To accomodate the early model right switchblock I ran the Red/Yellow wire from the mid-harness up to the right switch connector in the headlamp shell.
This setup has worked perfectly for the past 4 years, I hope some of you experts can shed some learning on my feeble grey-matter.....
thanks in advance
thanks in advance
