My nearly stock '82 Special is blowing headlight fuses and so far, I haven't been able to figure out why. All headlight wiring is stock; still have the RLU - saw no visible wiring damage when I removed it for inspection, and the connector seems to close tightly; no visible cuts/breaks in insulation on the headlight wiring inside the headlight bucket; all three grommets in headlight bucket holes are in good shape; fuse block is good (I rebuilt it two years ago using the Radio Shack method); headlamp has appropriate resistance readings between the ground lug and the high and low beam lugs, so is not shorted internally; headlamp plug is not shorted internally (no continuity wire-to-wire when removed from harness). With the ignition key either off or on and the beam selector switch on "Low", I have continuity between the ground lead in the headlamp plug and the yellow wire. With the beam selector switch on "High", I have continuity between the ground lead and both the yellow and green wires. I took the left side handlebar switch apart - none of the headlight-involved wires are loose from their solder points and there are no visible insulation breaks. Turn signals work fine. Subject search on the forum didn't turn up anything helpful. Any ideas would be greatly appreciated - thanx in advance.
