lettle
lsettle
Here is an odd one gents.
Tonight when I was checking the bike over. I pressed down on the rear brake, I notice that the rear lights and the headlight dimmed a lot, more then usual. I pressed down again and blow the 10A signal fuse. I replaced the fuse and press the front brake the brake lights came on as per normal.
At this point I pressed on the rear brake pedal, blow another fuse.... Replaced the fuse again. I thought it was my brake switch. I jumpered the Green/ Yellow to the Brown wires for the rear brake switch. Turned the bike back on, the light were dim. I switched the bike off again before the signal fuse blow.
I measured the Green/ Yellow wire from the rear brake switch is it is going to ground. I unplugged the rear light connector, no change, the Green/ Yellow is still going to ground.
Has anyone seen this before? Any ideas?
Thanks,
Lawrence
1984 XS650 5V5 Stock
Thanks,
Lawrence
