Have you checked the diaphragm's for leaks? Any cracks in the intake boots? The diaphragm check is fairly easy, esp. if the carbs are off the engine. In the throat, where you put the filter's, are some passages. On the top is an oval shaped hole. That is the port to the diaphragm. Lift the diaphragm all the way up (open), place your thumb over the oval hole sealing it as best you can, then let go of the diaphragm. If it falls down rapidly, the diaphragm is no good. They should drop slowly. As it's been said, the pilot circuit is very small, and easily plugged, even with a good cleaning. It can some work to get the crap out of the circuit. Very often overlooked, or just not cleaned out thoroughly.
