I am installing a Boyer Bransden MicroPower on my 1977 XS650.
Following this : http://www.650motorcycles.com/BoyerMicroPower.html
Meanwhile I ran into the following issues :
1) between the top engine supports, there is some device that looks to me like a condensor that was in parallel to the ignition points. Can that be permanently disconnected now ? (ignition points now gone and replaced by magnetic pickup unit)
2) After removing both original coils, I am still left with 2 orange wires (1 with dual female bullet connector and 1 with male bullet connector), going into the central harness.
3) Same for 2 gray wires (1 with dual female bullet connector and 1 with male bullet connector) going into the central harness.
4) At the same point in the central harness, there are coming out a short white-black and a short black wire.
Has anyone a clue as to where the wires mentioned in (2), (3) and (4) might be leading to ? In the electrical wiring diagrams I cannot find any corresponding connection... There is only a line for the red-white wire (power supply original coils) towards the stop switch, safety relay and brake lining indicator.
