Hi guys , I have a little problem with my 82 xs heritage special ,
i got the bike on an auction . It started right up but died as soon I hit the throttle. So I cleaned the carbs, put it back together and it backfired a lot ! Ok ,,,, must be the timing than - I opened up the point cover - "surprise " - empty ! No pointer plate ,no rod .
I ordered the complete Boyer ignition set- it came with an installation Manuel but they recommendet to go on the Boyer page cause there are more fotos and its ester explained.
After tones of research I can't find anything about the stock wire going to the ignition coil -
After the Boyer Manuel the red/white wire is in use but the orange wire from the ignition unit (after 3different wiring diagrams) is not in use .
All the posts are just confusing me and its also not in my mother language .
Thank you for every help , maybe it's just an easy thing and discussed a thousand times already (hope not)
