Breather Cover Assembly
Fraser
Ontario, Canada
The Breather Cover Assemble, we'd like to high temp, powder coat this unit.
Is there anything inside this unit that 600d's would harm ?
O.K. ? just what "IS" inside this unit that makes it work, or worth having on the bike then ? hahahaha
Always, any help will be very much appreciated
thank You.....
There's a tin baffle plate inside that breaks up and condenses the oil vapor. You should probably pull that out then re-install after powder coating the housing. Yes, you want to keep it as it is or too much oil vapor can blow out.
THANK~YOU.
The tin then ? it's the one behind the metal screen ?
I got the screen out, no prob. That thin tin "H"mmmmmmmmm ? it won't break will it ?
I put a really small screw driver to test if it wanted to come out...but, it must really be in there :( Worried about breaking it for sure.
But thank you,
to stop blow~by "H"mmmmmm ? interesting for sure eh.
f.
That breather mod is best done on racers only. Do it to your street XS and it will blow too much oil vapor out.
