Alright two steps foward three back. I never really noticed before but the rotor spacer I'm using for my Brembo and XS performance rotor (which is far less dished than a stock rotor hence the rotor spacer) doesn't center the rotor in the caliper as well as I thought.
Now since this is a fixed caliper rather than a stock floating style I'm not happy with this. Now I still have the rotor spacer provided with the bracket kit to fit the the Brembo with a stock rotor. You can see a gap between the hub and the motolanna spacer. My thinking is to use the rotor spacer (4.5mm) behind the motolanna spacer to push the rotor out more.
If anybody has any better ideas please say so. I'm not certain it will perfectly center the rotor but hoping it will get it much closer which it should. If the rotor has to be perfectly centered then I'm not sure what I'm gonna. I'm all ears.
