Okej, so when about to reassembly the clutch after fixing the starter gear issue, I now now noticed that one of the dampening spring on the primary drive gear was broken. Hmmmm... One thing after another...
I haven't noticed any rattling noise and everything seems to work fine. Or how does one notice that something is wrong...?
Is it a must to replace if only one spring is broken and there is no obvious problem? What would be the worst that could happen, that it slips out and cause other things to break down?
And if I have to replace, how the hell do one do that? There's no way to disassemble... I saw that xs650shop sells a kit with new springs and bolts/nuts. Does one have to drill apart the things first and then use the bolts/nuts? Is that really safe?
M
M
