You need the rod and at least 1 spring and ball.
Look at Travis's pics in previous posts he has a good shot of where the ball
and spring are located.
I believe gggGary was thinking about stocking some of the balls and springs but you need to check with him.
One other mod you might consider is another indent between full choke and half choke.
My experience was it needed some play on the throttle to go from full to half.
If you drill indents on both sides and use two springs and balls the positioning gives a firmer feel so you don't close it completely trying to find half choke. But I tend to overbuild.
*edited add on*
Any of the older left side(elec.) clusters will work if you want to get rid of the original with bulky molding for the choke lever or you can just take the lever off.
*edited add on*
