Mlwahler
Took my carbs apart after watching video on YouTube of adjusting floats.. I have an 81 with plastic floats. I bought rebuild kits from mikes. I pulled floats and cleaned carbs and installed new parts.. The question I have is in the YouTube video the floats appear to spring a bit when you push them. The new needles from the kit with the plunger work but one if my floats appears to just drop even if the tang is bent up there no spring to it... They are the original floats with the tube in the where the pin slides into...the end of the tube in the float in question appears to be a little oblong...will this be a problem. I don't want to use new plastic floats because I read they have there issues. Thx
