Okay, so I took the carbs off and did the fuel "T" repair that I found here on the site. I pressed the carbs back together and bolted up the lower support bar and the top plate. It was then that I noticed a very small ball bearing and a very small stiff spring laying on my bench. For the life of me I can't figure out where these two go or where they came from. The only thing I took off was the lower bar, upper plate and the enrichener rod. I had to loosen up the sync screw as well. Everything seems to be moving and working fine (off the bike). Can anyone tell me where these 2 little guys go? I've searched the manual and it doesn't even show the enrichener, and I can't find anything on the web. I'm really starting to wonder if it came from something else like my impact driver.
Any and all help is appreciated!
Thanks,
bpd106
Thanks,
bpd106
