cmattina1
So, I have carbs without vacuum barbs on the carb holders. From reading the carb guide I see that,
"Also note the vacuum ports available on the 38s (arrows). A suitable threaded nipple can be installed in place of the block-off screw to enable gauge hook-up for syncing. This is only necessary if you have no vacuum barbs on your intake manifolds ('77 and older). The size is a standard M6 x 1.00 ....."
Am I able to simply buy a threaded nipple (M6 x 1.00)from a hardware store or is there a particular one I can buy, i did not see anything on xs650direct.com
