MikeC23
I'm using the stock regulator on my 79 special. All of a sudden the regulator is buzzing and the bike won't start. Ideas?
What does the battery voltage read after it's been on the charger? Charge it overnight take it to an auto store and have them load test it. I'm with these guys bad battery is my prime suspect. While researching buzzing voltage regulator, a bad battery was a frequently mentioned culprit.
But what does it read on top of the solenoid when he hits the starter? Is the voltage 12 flat or 12.??? before he starts? The devil is in the details. Battery tests are usually free and probably conclusive. There could be a solenoid or starter issue. Pinpoint the problem then use the money gun. The suggestion of jumping with a big battery from a non running vehicle is good also. Could be a bad ground strap or connection issue also.
