Some of the newer Athena base gaskets come pre-treated with heat activated sealer. I believe this is one of them in my pic. You don't need to treat them with any added sealer. Usually, on an untreated base gasket, I do like to use some sealer, but I don't use Three Bond. I used to use a liquid type of some sort but following a tip here, I've changed to spray-on Copper Coat. I put it on the head gasket too.
Technically, you shouldn't need sealer, the gasket should be enough, but it's common practice to use it on rebuilds. The factory may not have used it but they were dealing with fresh, brand new parts. I used a liquid gasket sealer on my base gasket when I did my topend like 10 years ago and it's never leaked. My head gasket, on the other hand, has given out and is leaking. I just used a few added rings and lines of Three Bond (Yamabond) on that. I wish now I had used more, lol. When I re-do it, I will be spraying the entire gasket with that Copper Coat. Hopefully that will seal better/longer.
