It looks to me as though there had been two drilled holes in the engine case and then filled with epoxy. I have looked at photos of other bikes and seen the same thing. Anyone know what these are about?
I'd guess they're aluminum plugs driven in. Take your meter and see if they conduct electricity.filled with epoxy.
those are oil passages capped off. Since no one has invented a drill that will turn corners, the factory has to drill multiple passages that intersect
Yup....too bad about that. Dormer ran out of those handy right angled drills quite some time ago and they never seem to re-stock the danged things. They're probably in the same shipping container as that load of metric adjustable wrenches and micrometer vice-grips I ordered all those years ago. All kidding aside, those are sometimes called cross-drilled holes and they are very common in engine and gearbox lubrication systems, cooling systems in injection molds and so on.
I'll bet 98% of XS owners have never noticed those plugs....you're a pretty observant guy Mailman!
Fred: do you use inch or metric cold chisels?
Ahahahahahahahahahahha
Maybe that's the reason it's on the trailer. : )
