Sure with a permanent magnet charging system. There has been a lot of discussion about this. Try the two search boxes above just below the navigation menu.
Basically the stock charging system needs power to make power so you need a battery. If you convert to a permanent magnet charging system, the charging system makes power whenever the crank is spinning.
