XS Ignition Questions
Mark ACC
15228
I'm looking to retro-fit my '83 XS tracker with a stock ignition system and have a few questions for you electron freaks:
1. Is there any meter tests I can do with the stock rotor/ stator to see if they are good? Should I just take them to a generator shop and have them check it?
2. I hear tell that a Suzuki GN 250 TCI unit will fit up to and work on a XS. Is this true, and if so, will any year GN 250 unit work? They made that bike from '82 to '97
Really appreciate the help boys!
Found in tech These should answer your questions;
https://www.xs650.com/threads/expanded-charging-system-guide-in-progress.10561/
https://www.xs650.com/threads/gonzo-diy-tci-system.57694/
Jim does a great write up on the charging system in here, Post #2.
https://www.xs650.com/threads/rewound-alternator-rotor.54276/
He also does rewinds. If you have to get a new rotor, it would be better to buy a dud secondhand one and get him to do a rewind. He does exchange rewinds............Some aftermarket new ones have been found to be problematic in the past
