i believe i may have a bad seal on my carb float needle because i get gas to seep out of the carbs when not running
i have taking the carbs apart several times and noticed that there is a small grove in the needle, i have tested the floats and they are not leaking and have adjusted them to the correct height
i was going to order a new from mikes but i feel that there is some mislabeling on his site i have a 78 with what i have identified as the stock carbs using his guide so i should use the part number 48-5019 but my needle look more like part number 48-1429 which is for the 70-71s
any help on identifying this confusion or ideas on why else the carbs are flooding
