Finally got the bike registered, and have put about 40 miles on it. Seems to run worse the longer I ride it. Stock jetting, 135 main, needle clip middle position, 27.5 pilot. The last thing I changed was putting the needle in middle position. This is the longest I've run it continuous, all previous rides were maybe 1/2 mile. Seems to cut out every so often, and sputters either out of the carbs, but sounds more like it sputters from the exhaust. Warmed up, and idling it sputters from the exhaust, like putting your hand near the end of the exhaust it lets out a pffft every few seconds. Going down the road it just cuts out briefly, but doesn't die. Sitting at idle if I remove a plug wire it stays running, however it runs higher rpm with one compared to the other. Doesn't start easy compared to in the past. Always was one kick, two at the most, now its like 5-10 kicks, and it doesn't always want choke even if its cold. Do I have a needle valve sticking? Any ideas? Checked the timing again, and its on the F at idle, though I don't have a tach so I don't know exactly the rpm.
