Usually, with everything set right, these are easy starting machines. And they usually kick start just as easy, if not easier, than electric start. On the one hard starter I worked on, the issue turned out to be improperly set float heights. The fuel levels in the bowls were too low which I'm guessing was starving the bike for fuel, especially when a richer mix was most needed (during start up). So, when you install the new float needles and seats, do carefully check the float levels to insure they're correct. This is what I found on that hard starter, much too low .....
