I think if your crank and rods are in spec, the repair manual tells how to do the measurements, I would just use it. To break down the crank to replace just the rod bearings is a lot of work. I did two awhile back, not hard to do with proper tools just time consuming.
If you do break the crank down replace all the bearings and use new rods. You will have them all off anyway to press out the crank pins the rods are mounted on. The parts will run you $500-$600+ the rebuild of the crank.
The new 5th gear is popular. The cam chain, new front guide is necessary.
The 750 kit a new set of clutch plates helps, the extra power can make the stock clutch slip. I might try roughing up the old fibers and cleaning off the discoloration and burrs off the steels a bit with sand paper. A new bearing with more rollers like Mike's sell is a good thing too. If it still slips, go with stronger springs, if still slips then a set of Forodo clutch plates will help.
Or just clean up the steels and put in the Forodo's and heavier spring to start.
