T-Sox
Wrench Monkey
So I have been looking into the Banshee PMA swap and thinking about a Pamco ignition for my bike. I'll admit I'm not the sharpest knife when it comes to electronics so bare with me.
The Banshee flywheel and stator has a pickup signal coil on it. This tells the plugs when to fire based on the flywheel position. The stator has the magnet that triggers the firing through the CDI. This is the same as a Pamco only better IMO. Why couldn't you leave the pickup coil, run it into the correct CDI for ignition? Basically stealing the complete system from a Banshee (like the one linked below) it should work if you can get the timing right. It may require a new keyway groove in the flywheel depending on where the pickup would need to be in the case but the backing plate in the kit below is adjustable to it could be fine tuned.
http://www.ebay.com/itm/Kit-Stator-...ash=item3ac98d7151:g:yq0AAOSwhOdXpOE3&vxp=mtr
Am I wrong or am I wrong?
