1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Changing Rear Tire
Discussion in 'The Garage' started by ms4griff, Aug 14, 2019 at 5:28 PM.
  1. ms4griff
    ms4griff XS650 New Member
    Hey All -- newcomer to this site and a one-year owner of a 1977 xs650 in pretty great, original condition. I picked up a nail in my rear tire and, since tires are OME, think this is a good time to change them out. If I order a tire online, is it super difficult to change by myself?
  2. motormike
    motormike XS650 Junkie Top Contributor
    517
    1,122
    143
    Mpls
    … got a manual.. stock pipes ? Manual doesn't mention you have a open swing arm... which means.. the rear wheel will slide out the back of the awing arm..w/o pulling the axle... just remove the bolt at the end and on top of the s/arm and remove the block.... if you pull the axle.. use a towel.. and place each item in order of removal….this will aid in reassembly... prior to inserting the axle.. a light coat of grease is recommended... the master link can be removed.. just insure it's installed properly afterwards. Ck U tube... sometimes the procedure is posted.
    gggGary and Machine like this.
  3. Machine
    Machine Race the wind Top Contributor
    Yes, wheel removal at home in the very least is best.
    Carry the wheel to a shop if that’s your plan?
    Actually changing the tires on the high shoulder aluminum rims should be done by experienced tire changers.
    Those wheels are a bit easy to damage.
    Are you a tire changer in the past ?
    gggGary likes this.
  4. ms4griff
    Nope -- I like the idea of carrying the wheel to a shop. That's a good plan --
    gggGary likes this.
  5. solo2racr
    solo2racr Suck, Squeeze, Bang, Blow
    Without the PROPER tools.....No. Don't bother trying to change it yourself. Like was mentioned before, un-mount the wheel and take it to a good shop.
  6. 59Tebo
    59Tebo 59Tebo Top Contributor
    ms4griff,
    Agree, agree, agree!!! with those who say "...take the wheel to a shop". I had OEM tires on "The Basketcase" (a '75), and this bike had sat outside for years! Suffice to say, they were hard as a rock, and I damned near wrecked :yikes: the front rim trying to remove the tire with "spoons". Since I'm going to replace them with all new everything (the last parts I order, in the hopes I have the newest tires possible), I cut the sidewalls with a utility knife, removed the carcasses (carcii?), and hack-sawed the beads to remove said sidewalls. You might get away with saving the tubes, but why? Clean house, and be secure knowing everything is as good as it can be. In the long run, it's cheap insurance. :twocents:
    peanut likes this.
Share This Page
