Brett
After the first 50 miles since I built my bike, the battery died (Shorai lithium) and the bike would not kick start. I charged the battery and tested the voltage across the battery and it's not charging (12.5 volts at idle and the same at 2000rpm).
I've gone through most of the usual checks. At first I thought it was the rotor as there is only 2.8 ohms across the slip rings. However the rotor and stator have been rewound. I spoke to the company in the UK that did it (very reputable) and they assured me that 2.8ohms was ok because the wire they use is thicker and it was tested to work. They suggested I test the regulator/rectifier.
I am not able to start the bike at the moment (to do the green wire test or a/c voltage between the white wires) but I did the diode test in the meantime.
I get correct readings between the red wire and the white wires, but NO reading either way between the black and the white wires.
I've done most of the other checks: There is just under 12v at the brushes and 0.5ohms between all three white wires from the stator. The rec/reg shares the same ground as the battery and there is good continuity)
Does it sound like the rec/reg is bad without doing the other tests? (could the black/ground wire be damaged inside the reg/rec?)
Thanks, Brett
Thanks, Brett
