bdholsin
XS Enthusiast
Ok guys, I'm a little confused. My battery died today after riding to work. Let me rephrase that...my battery was low on the way to work. Just after pulling out this a.m. I noticed my blinkers weren't blinking. Ok, no big deal. I rode 15 miles on the highway and when I went to exit I hit the blinker and it was blinking fine.
Parked the bike and put in 8 hours. Went to start it this afternoon and there was absolutely no juice in the battery. BTW, the battery is only about a year old and I used a tender throughout the winter. The old girl fired after a couple of kicks and I motored home. I did notice that, once again, my blinkers weren't blinking.
My thoughts are:
1. Bad charging rotor. I'm yet to pull the side cover and ohm it out.
2. Bad regulator/rectifier.
3. Bad battery. Despite being only a year old, it could be bad. It's on the charger right now.
Let me think this through. The bike won't start with the electric leg but will run after a couple manual kicks. So this means that it's running off the alternator, right? If that is so then the rotor should be good and the regulator/rectifier is bad. Is my logic sound so far?
I'm bone tired tonight and just can't figure out what's going on. I'm open to thoughts/suggestions. First thing I'll do tomorrow is ohm out the rotor slip rings and report back. In the mean time, if anyone has thoughts, I'm listening.
Thanks!
My thoughts are:
Thanks!
