jchrisk1
XS650 Junkie
My rotor went bad a few days ago and I replaced it with one a friend had. The new one read 6.3 ohms. I have been trying to check everything and I'm getting some weird readings.
When at idle, I'm getting anywhere from 13.8ish to 14.5ish. And it's really sporadic. When I rev the motor it goes up to 15.2. I've been going through the charging system checks, and at the black wire on the brushes I have .01v and at the green wire I have about 9.7v. I think the black wire is supposed to be the same as the battery. Also, my battery is reading 13.3. Doesn't that sound high? I've tested the three white wires at the stator plug and they read 1.0 ohms. I tried jumping the green wire from the reg/rec and it really doesn't change anything. The voltage will rise and fall just as it does at idle.
I'm trying to understand why it's reading sporadically. I haven't checked the ignition switch connection yet, but I am going to right now. If I understand correctly, the ignition sends the power to the brush on the black wire.
