Sparky
Hi guys. I'm having trouble charging.
The charging system is all stock 1981. It was working, at least to some degree, until recently when I had the engine rebuilt. None of the wiring was messed with, aside from unplugging connectors.
Ive read through gggGary's "expanded charging system guide", and I think I understand most of it. My job is working with DC circuits and voltmeters, so i'm knowledgeable there. My battery is good, and most of the testing ive done today was while hooked to a trickle charger. The diodes in the rectifier check out okay.
The resistance on the rotor is only 1 Ohm, the charging guide says it should be 5. Before I buy another rotor, is there any further testing I can do?
I'm not getting 12V to the alternator brush (the bottom left, the outside ring). in fact, that one read about 3 volts. the Inner ring brush reads 10.5. When I disconnect the outside ring brush, with key on, I get 0 volts to the outside wire and 12 to the inside wire. I also get less than 1 ohm resistance from keyswitch to inside ring wire. I attempted to run a hot wire from battery to the outside wire, to see if it would start charging, and it immediately popped the 5A inline fuse on my jumper wire.
So i've got 10.5 V on the wrong brush, and low resistance in the rotor. whats going on here?
