freddy3
- Messages
- 479
- Reaction score
- 120
- Points
- 43
Is it age or something else that's causing the bike to require ~10 minutes idling with the starter jet lever (choke) ON before it's drivable with the choke OFF?
When cold, the bike usually starts with one kick (or a coupla cycles of the decompression lever) with the starter jet lever (choke) ON. However, it'll stall or misfire if I switch the choke OFF and try to drive it until it's been running (with the choke ON) for at least 10 minutes.
With the choke ON, I can drive right off without any problem and, then, just switch it off after ~8~10 minutes. But, according to the owner's manual, driving with the choke ON is NOT recommended; the manual states that the choke can be turned off within a minute or two and drive fine after that. So I'm stuck sitting around for 10 minutes before I can drive.
If I let the bike warm up for ~10 minutes before switching the choke OFF, the engine runs beautifully after that.
The carbs and petcocks have been rebuilt (multiple times!), the tank cleaned and the timing's spot-on.
What's the reason for the extended warm-up time or is it safe to drive with the choke ON for a few minutes?
