gray am I
Hi, I was having trouble measuring the tension with a digital spring scale until I realised that there was a burr scraping against the side of the clip that was cutting into it, this came from the bottom of no 4 gear that had been grinding away from not engaging properly. After I used a fine slipstone to polish the burrs off, I got a reading of 4lbs and after closing the spring up I an getting about 7lbs.
I am assembling my clutch after I (hopefully) fixed my starter spring but my Clymer manual does not give torque specifications on the clutch lock nut, or spring screw can anyone please give me the settings, searching doesn't help as I'm getting conflicting values.
As I don't have any spare clutch plates here is my version of a clutch holding tool.
