Final have some funds and time to get some parts for the bike and can't find the links I use to have to the good EZ pull clutch cables and stainless front brake lines. Any suggests on what I should look at?
650central/ for the Ez Pull clutch cable. As for the Stainless brake lines, MikesXS has them. There are some other sources out there and they can be expensive. What's I've done is just search ebay, looking for the correct 10mm banjo ends (pretty standard) and the length I need.
I use Motion Pro from Motorcycle super store for my clutch cable, it works good, better then mikes which broke 300 miles in. I also switched my throttle cable to since I was in the area.
Without starting a war. Is there a big difference between feel and durability in the stainless steel brake lines? I still have the original master and caliper but the old line is feeling soft.
Yes, it's huge. If you are changing the line, go stainless. You will use less lever travel for effective braking and can modulate much better.
My Opinion, Motion Pro for ANY cable, any bike.
Both are great products. Motion Pro has the "Terminator" line for off-road that is made the same way as the EZ pull (made by MSR) Not sure what the street version is, but I'm sure they make it. Can't go wrong with either one for the clutch. Just gotta make sure and lube the balls and pivots when it goes together and keep it all working smooth.
