So here's my specs:
1981 xs650 special
650central clutch cable
Brand new mikesxs worm gear using inner cable mount- mikes worm gear has 2 cable attachment points to choose from
650central perch
Adjusted lever and cable using advice from tech section.
Here's the problems:
1 Neutral light always stays on
2 Very difficult to find neutral- easiest if I drop down to neutral from second
3 At a stop, With clutch lever engaged, the bike still wants to creep forward when in 1st gear or it wants to kill when in 2nd gear.
4 When in neutral, with bike off, and I roll bike forward- I can hear gears turning inside case even though it rolls ok
5 sometimes I just can't get the bike out of second at all while at a stop. In other words, if I pull up to a stop sign without having downshifted into first prior to stopping, then it gets stuck in second and I can't drop down to first
As you can see, something is way off and I don't even know where to start looking. I recently had the clutch and right side covers off and very thing seemed visually to look ok
1981 xs650 special
650central perch
