This is the best one I've got / seen...
Yes Sir - Thank you for this.
I have been scratching my head .. having many clutches in boxes and washers of different types.
My own fault.
Took it apart many years ago and now not having all parts from the same clutch.
Had a to weak holding tool so it folded and i Broke off an ear on d.
Putting it together as the section drawing. Seems right. for me.
I had the wrong washer an e instead of an a .So when i tightened the nut k --- h would not turn.
I found that a washer in another bag.
The splines was also tight so h would not go all the way in.
Making me believe the excessive axial play was because of something wrong with the washers.
But with a little turning ..shifting position .. it slided in .Without force.
The smaller outer diameter of a is not shown clearly at any other place i Know off. As in the section drawing.
There are some videos .But this appears right for me. Thank you again " top notch... "
