Hi guys been a while... I have recently fitted barnett plates and springs and the longer actuator (OMG its sooo much lighter) I have also used car oil not bike oil, this might be where I went wrong... thing is I am pretty sure the guy in the car shop said it was API SL so should be fine? after some research I have failed to find out online the specs for the oil I have bought, it is Lexicon 20w50 mineral, says suitable for petrol or diesel and high millage or older engines which would suggest its of an older spec....
I was running lucas plates and EBC springs, the lucas plates were a thinner friction area and I think this was causing my clutch to be quite grabb'y and harsh, also to avoid slip had to put washers behind the springs, the new barnett springs are longer by about the washers length so left the washers out, also bought some wiseco springs and they were the same length as the barnett but when tested using digi scales in my piller drill the barnett ones seemed to be putting more pressure down... the barnett plates seem much better and have loads more feel, likewise the longer actuator and replaced the pin as had worn w shaped, I have also fitted the plastic blocks in the cush drive as had destroyed the springs....
It still slips if I really nail it especially in 4th, so.. I am running SP370 pistons (840) XS1/2 camshaft (swapped the sprockets over) standard yamaha electronic ignition and 34mm Amal Mk2's so its moderately tuned but its not re-phased or race cam or anything, I'm running a 7 plate set up out of a 77 D model, I will re check the push rod adjustment when it has cooled down as I have only just got home... I know a lot of you go to 8 or 9 plates is this the only way?????
