xs650newb
Hey all,
My 1977 XS650D is running way to hot.
I went on a 15 minute intown ride. Rarely broke 3K rpm and kept it under 40 mph. It is about 85 degrees out right now and my wife was on the back. The plugs are white with a faint hint of brown. Definitely too white for my taste though. Also, I took some temps after the ride.
Top of crankcase (near where you put in oil): 220
Head near right spark plug: 280
Pipes as close as possible to exhaust port: 390
The bike is (almost) completely stock. I recently cleaned carbs (stock jetting), set the camshaft tension, and set the valves.
A also searched for air leaks and couldn't find any. My method was to spray wd40 in various places and look for a change in revs of the bike at idle.
Here are some caveats:
1) The airfilters were rotted out so I removed the old foam and put in new unifoam foam and glued it to the metal skeleton of the old air filter.
2) The bike run Ok and starts GREAT. It starts within 1 revolution using the electric starter or with a single kick. I choke it for 5 seconds then turn off the choke and ride off.
Runs great initially then I feel a slight surging once it is warmed up and it will bog down if you crack open the throttle. It accelerates real quick after bogging down for about 1 second.
Any ideas whats going on?
Best,
Adam
Best,
Adam
