Going to look at a non-running bike tomorrow morning. Went by Autozone and borrowed a compression tester. Thought I'd try it out on our XS that runs very well (but is currently almost completely disassembled). Pulled plugs, coil is already removed so no need to ground wires, held carb slides open and kicked many times. Highest reading I got was about 50psi in each cylinder.
Based on the target numbers I've seen - 135 -150, I'm wondering what I'm doing wrong. Surely a well-running motor couldn't have only 50psi per cylinder.
I'd like to test the compression on the bike I'm looking at in the morning, but I'd like to get readings that actually mean something.
Any advice would be welcome.
