150 is a great number for these engines and even more important is that both are within 5-10% of each other.
Now save that compression tester and remember to use it each time you re-check.
That way you get more consistent readings using the same gauge and accurately test whether it's getting weak or not.
The biggest thing that can give you false readings is excessive carbon on the piston. Everything else gives you less, leaking rings/valves/gaskets.
Look in the plug hole for signs of carbon and if relatively clean you are good to go.
My guess, Your Fine.
