Peejay
Hi guys,
Seeking opinions here.
I tore down my XS650 to replace the cam chain tensioner guide after discovering usual bits in the oil.
As can be expected from all the great info there are other things to do but I decided not to split the crankcases but to wash out the bottom end and then started to see reddish metallic stuff in the washout.
Hunting around I found red copper sludge in the gearbox end of the sump and I have flushed out as much as I can find. We called it Copper Slip over here in the UK and used it to hide bad gears noise in cars
My question is - can this stuff cause problems elsewhere? Why would it have been added?
the gears all selected and ran smoothly before the strip down. Have I uncovered a problem?
My guess is that a PO has used it to quieten the gears as this was a trick used years ago but in separate gearboxes from the engine/clutch arrangements.
My fear is that there is something I don't know about going on and I don't want to do unnecessary work but how far should I go?
Has anyone seen this before?
Should I check out the gearbox?
Is anything else ruined by this stuff? The clutch did seem to slip at about 5000 rpm so I had already decided to up rate the springs. Was this unnecessary?
I don't want to rebuild everything and find I should have gone further.
Any opinions/suggestions/ideas guys?
Peejay
Peejay
