1. Dismiss Notice
    Dismiss Notice
Correct gas cap gaskets needed for 1973 TX650
Discussion in 'The Garage' started by velocejoe, Feb 10, 2019.
  1. velocejoe
    velocejoe XS650 Member
    I replied in a thread I started over the seat foam which is a one year only.....but figured I would start a new thread for the gas cap gaskets.
    My 1973 TX650 is in need of the gas cap gaskets, the one "long" o-ring type thing and the one that goes around the metal disc that touches the tank. I am assuming the 1973 is a ONE YEAR ONLY gas cap...just like the seat. I cannot tell if the 1972 TX650 has the same gas cap or not.
    DogBunny posted the TX650 specific parts manual showing the correct seat with part numbers. He also posted along with it the fuel tank section....but part numbers not included. I would love a link or a pdf if someone has it of the TX650 specific parts manual. Tired of banging my head against the wall every time I need something.
    Paul Sutton likes this.
  2. velocejoe
    AWESOME AWESOME AWESOME!!!!
    Paul Sutton and TwoManyXS1Bs like this.
  3. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
    TwoManyXS1Bs likes this.
  4. TwoManyXS1Bs
    Paul Sutton and GLJ like this.
  5. velocejoe
    Those won't work on my 73 I don't think. Looks like I might be missing some parts to my gas cap??? gas cap1.JPG gas cap2.JPG
  6. velocejoe
    I ordered the KDI Reproduction kit once I found the correct part numbers. I've done some CT3 and LT2 caps before....seems like I remember more parts to the cap and parts manual shows more as well.
  7. velocejoe
  8. GLJ
    Contact the guy. Explain to him what you have.
  9. DogBunny
    DogBunny Motorcychologist Top Contributor
    There is a huge lip that is supposed to be on the underside of the gasket in your pics that is missing, but the cap works without, and your cap is otherwise complete.
    What really matters is the part of the gasket that contacts the neck on the tank, and that part on the gasket in your pictures is in perfectly usable condition, and will probably out-last the reproduction that you just ordered from eBay.
    Paul Sutton and gggGary like this.
  10. velocejoe
    That existing gasket on my cap is hard as a brick. Gas stains on tank from previous owner. The cap does not seem to shut down very tight....I'm afraid it will leak, even with new gaskets. That "lip" you are talking about is for the 1974 versions. I believe there is a whole "nother" disc that goes on top of the base disc that helps push the whole assy down onto the tank flange. I might just be able to get a thicker gasket/O-ring and get it sealed up that way.
  11. velocejoe
    I contacted the guy who sells the complete caps on ebay (though he is out).....sent him pics. His response "I'm not familiar with that kind of cap. Good luck."
  12. velocejoe
    Anyone willing to take there 1973 cap apart and post pics of what all it's supposed to have?
  13. velocejoe
    Just want to at least have a basis on what I have vs what I'm supposed to have. Man, these one year only bikes can get the best of you. 3 hours of research so far just on the cap.
  14. velocejoe
    A good 5-7 hrs researching and building replacement seat foam :(
    gggGary likes this.
  15. DogBunny
    You might be right about your old gasket being hard and leaking. But 1973-1975 caps are all the same. You aren't missing anything, just the big, non-critical lip I mentioned.
    The thumbnail below has the part numbers for that 1973 seat diagram that included the gas cap that I posted in your seat thread. You should find that the parts and numbers are identical to the 1974 Partzilla diagram link that I provided.
    Team Junk, Paul Sutton and gggGary like this.
  16. 650Skull
    650Skull Dinosaur Lives Top Contributor
    73-75 TX/XS650........73-75 TX/XS500..........73-74 TX750 all have the same gas caps.........
    I'm sure the 73-75 RD250/350 Gas caps are the same as well
    74 TXA-75XSB Parts manual102.jpg 74 TXA-75XSB Parts manual103.jpg 74 TXA-75XSB Parts manual105.jpg
  17. 650Skull
    TwoManyXS1Bs and Paul Sutton like this.
  18. joebgd
    joebgd XS650 Addict
    297
    75
    28
    NY
    You can get gasket material and make your own.
  19. velocejoe
    I ordered the Viton orings. Going to give that a shot. I'm also going to try them as exhaust gaskets on another bike I have!! They are rated to 500 degrees.
Share This Page
