pregrid
XS650 Guru
After finally getting the tracker on the road the only real problem I have is a countershaft seal leak (and a pretty good one at that). After removing the sprocket and seal I found out why. I don't know if the chain broke at some point, the chain just flat wore out, or someone was using too small a front sprocket, but much of the seal boss is ground off (see pic). The leak was between the seal and the boss. In fact, when I tried to pry the seal out it pretty much just fell out. On the new seal I have there's a lip that runs around the outer diameter and looks to correspond to a groove cut into the boss, presumably to help retain the seal. However most of that groove is gone. I've thought about just gluing the new seal in place(with something like The Right Stuff or something similar) but I'm not sure it will hold. I've also considered getting another seal that is half the thickness. I don't wanna find another case at this point so anyone have experience with this sorta thing?
Posted via Mobile
Posted via Mobile
