chopit25
So I chipped some bondo off the frame, it had a shit ton of it and even the gas tank was welded and bondo'd to the frame. Ground off a couple of brackets too. After that I was using a 120 grit flap disc to clean up the areas and I found this under the paint.
This is right where the hardtail section connects to the top of the backbone. FUCK!
I already noticed last week that the axle plates section is WAY too tight. Had to really pry at it to get the rear wheel back on.
So I started looking closer and at other hardtails. On the bottom rails there is no support aft the cross brace under the backbone. Also the only rear cross support on the the top rails in a flat piece of steel to mount the fender to.
I am thinking it may be best to cut the whole rear section off and get another hardtail and start over at this point. I don't know what to do with this thing now. I can't afford crap right now but I was so close to getting it ready to atleast ride a few times before a winter tear down that I don't want to just sell it and give up now.
But I don't want to kill myself on an unsafe machine either.
Am I overreacting here? I don't know anyone local that could weld on a new hardtail either. I need to learn to weld! Lol
Anyway what do you guys think about this?
