I pulled this from some other forum out there, a guy was asking about hich coils are compatible with his Boyer -
"you have to know the primary side ohms. points use a 4.5 to 5 ohm primary, the electronic use 3 ohms or less, using the wrong one can damage the ignition system. what does the boyer call for? any coil that matches their spec's will work. on 650 central there boyer coil has a .6 ohm primary. the 04 -06 sportster coil is .6 ohm, older coils had 3 ohm primarys"
So since I contacted Boyer and they spected a 4.5amp, I'm assuming any 4.5amp would work.
