- - - Suppose I'd better get the right valve springs in that pig if I want to ride it. Damn, i don't want to take it all back apart a THIRD time this re-build... tossing un-fired gaskets gets on my nerves. ;-)
Hi Ernie,
so what's wrong with the valve springs that you need to change them?
It may be possible to change the valve springs without pulling and dismantling the engine. Depends if you can remove the rocker pivots in situ.
Feed a length of rope in through the sparkplug hole (leave a tail hanging out to remove it afterwards), bring the piston up to compress the rope against
the valve heads to hold them up and force the spring collar down to remove the retaining collets.
