xs650special
James
I finally figured out where my XS is leaking from: the left side cylinder oil drain. I'm not sure that is exactly what it is call. It is where the oil gravity drains, I think, back down into the motor. Long story short I did my first valve job and on the first try I ended up having the adjuster tappet put a hole in the oil drain area. After getting the valves and torqued to the right specs, I did a couple compression tests and the left side, the trouble side, read 155 PSI. The other side was 145 so there is no compression leaks but when the bike is running it sprays out oil. I have a couple of thoughts, to either replace the cylinder head with a new/used unit or have it heliarc job done. Anyone have an opinion?
