Hi All!
My XS is a 1977 ("D") model, so it has 35 mm forks, but no top out springs as standard.
The "clunking" these forks make when they occasionally do top out is a little bit unnerving..... So I would like to modify my forks by installing top out springs, and at the same time I get the added benefit of a little shorter forks.
I am looking at the selection from a supplier of springs, and need to know the exact outside diameter of the damper rod (for correct spring ID), and outside diameter of the damper piston (for correct spring OD)
I am sure somebody have some damping rods handy for measuring
My plan is to install springs with a free length of around 30 mm, reducing the fork stroke down to 120-125 mm.
