If you're putting the same rim (or replacement that's the same) back on the same hub, you might want to take some rim to hub offset measurements before you disassemble things. If you're using a different rim, you'll have to do some math. Basically, on 650 wheels, the rims are centered over the spoke flanges. This isn't necessarily the center of the overall hub width. This is particularly true on the rear. The sprocket side sticks out more than the brake side.
