Your jets are mounted in the float bowl, not into the bottom of the main body like most other carbs. The main jet is under the drain bolt on the bottom of the bowl. The pilot jet is on top of the bowl. The gasket will have to be off the bowl (if it happened to stick there) to see it. Your bowl and pilot jet will be the type on the left .....
Removing the main jet .....
..... or if it's really stuck .....
Perfect fitting screwdrivers are imperative. The jets are just brass and the screwdriver slots in them are easily rounded out or damaged. I've taken to custom grinding 1/4" screwdriver bits to get that perfect fit. The loose fitting bit on the left, the one that's cocked into the jet, has not been "custom" fit .....
