Here's a poor copy of the early XS parts list for the swingarm. Note the part number changes on the XS2's pivot parts, including the optional shims. May need to pull it back out and double-check protrusion of pivot tube out of the bushings...
Correct me if I'm wrong guy's.
But according to 5twin's, the tube need's to stick out past the bushing's. Right. So if I just keep tightening the nut with out setting the bushing's in farther, the bushing's will just go in as long as the tube. The tube will never stick out past the bushing's. Right.
Am I thinking of this right.
If you took the tube out and tightened the nut down you might be able to use the bike as a jig to press the bushings in enough that the tube would stick out the ends. I'd try it myself. Beats filing if you don't have to. The other alternative at this point involves going to get all-thread and big washers. Unless you've got a press.
^ I'd use the old bolt and nut for that trick instead of the new, in case it has to go really really tight to do the job.
But the old nut and bolt has left the building.
If you're using the original tube set-up, then you have 3 tubes. The newer bikes did away with that and just use one long tube. On yours, that center tube won't go through the bushings, it's just a spacer. The outer short tubes w/ the grease swirls in them fit in the bushings. But, the same principal applies - your 3 tube "stack" should protrude slightly from the arm and bushing assembly.
Ok guy's. Here's what I've got. Remember, this is on my 72.
1. Tc Bros bronze bushing's.
2. New 70-73 swing arm bolt with Nylock nut from mikes.
3. new grease seals from mike's.
4. Thin shim's from original set up.
5. Pivot tube stollen from my Son's 79 bobber project. I'm sure I read this was an upgrade for the 72.
When I put it together, it just seemed like the nut would just not reach 50 ft lb's. It just kept turning. Should a nylock be able to get that tight with out stripping.
I think maybe what is going on is I'm just not tightening it up tight enough. I thought the nylon went all the way through the nut. Not just the edge. I thought I was stripping it.
When I get home tonight I will re-torque it and see what happens.
I have to admit that I can't remember exactly where the pivot tube ended up. This is driving me crazy. I'm fairly sure it is not sticking out the end's though.
I'll post back later. Thanks.
